ls2 swap in a 97 z28
Old Oct 2, 2007 | 07:36 PM
blair's Avatar
will i be able to swap a ls2 for my lt1 and how hard is it to swap a t56 for my 4l60e
Old Oct 2, 2007 | 08:22 PM
danhr's Avatar
yes
not that hard
Old Oct 2, 2007 | 08:54 PM
blair's Avatar
will i need to change motor mounts and get a new ecu and is there anything else i will need to the motor swap?
Old Oct 2, 2007 | 09:00 PM
danhr's Avatar
search over on ls1tech... you will get a detailed list over there... off the top of my head
you are going to have to replace parts of your body harness, run new fuel lines or use a corvette external fuel pressure regulator because the ls1's just have a feed line while the lt1's use a two line system, you will have to move your tranny mount back about 2 inches, swap out front k members, steering rack, pcm, reflash your new pcm to correct for the tach, new pedals, center console, master cylinder, new tranny cross member,
and of course an ls2 and an ls2 t-56 and a clutch and flywheel
i'm sure i'm forgetting a few small things but that's about the jist of it
why an ls2? you can get an ls1 or lq4 drop out pretty cheap nowadays
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
Hotrods&Muscle
Jan 18, 2015 08:08 PM
cmdeshon
Jan 4, 2015 11:15 AM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
