Can someone explain AN fittings to me?
Old May 27, 2003 | 11:15 PM
Alvin@pcmforless.com's Avatar
I just don't get it,
How do the sizes compare to standard plumbing sizes?
I know that the stock feed line is 9mm and i'm using a 3/8's compression to handle that fine and the return is 7mm if memory servs correctly and i'm using a 5/16th there.
It works, but i don't like the brass fittings on the car. Would rather have something a little more professional looking.
Also, has anyone been able to tap the stock fuel rails? Like with regular pipe threads?
Old May 28, 2003 | 12:10 AM
Brady's Avatar
an easy way to remember -an fittings is to put /16" on the end.
Example -8an = 8/16" or 1/2"
Example -4an = 4/16" or 1/4"
Example -10an = 10/16" or 5/8"
For the fuel rails, we welded -8an fittings on them. You might could tap them, but I haven't tried it.
Old May 28, 2003 | 12:12 AM
AN Size - Equivalent metal tube OD
2AN - 1/8"
3AN - 3/16"
4AN - 1/4"
5AN - 5/16"
6AN - 3/8"
8AN - 1/2"
10AN - 5/8"
12AN - 3/4"
Comparison of NPT ID to closest AN size:
1/8" NPT - 4AN
1/4" NPT - 6AN
3/8" NPT - 8AN
1/2" NPT - 10AN
3/4"NPT - 12AN
Source: "How To Install & Use Nitrous Oxide", Joe Pettitt
I have -6AN fittings welded into the end of each fuel rail for fuel inlet. I have a 1/8" NPT fitting welded to the middle of the passenger rail for a fuel pressure gauge tap. I have a -6AN fitting welded to the diagonal crossover pipe for the return line.
Old May 28, 2003 | 11:01 AM
Wow, thanks a ton guys
Old May 30, 2003 | 04:07 PM
Phatcaprice's Avatar
Thanks, that was helpful for me too.
Just WITF did they do that!?!?
Old May 30, 2003 | 04:19 PM
This may help too:
http://www.speedwaymotors.com/produc...RSSEKK3MSC5MNE
Old Jun 1, 2003 | 07:58 PM
NOMAD's Avatar
Cool
I've got a drilled and tapped for AN on mine for the fuel press guage. I actually believe only one end was AN and the other was Metric... I'm not sure since i'm new to them also...lol
http://nkyfba.homeip.net/modules/Gal.../JamCam629.jpg
-Shannon
DirtyDaveW
Dec 1, 2016 05:37 PM
Apr 3, 2015 10:54 AM
BigWil
Mar 29, 2015 12:24 PM
mschmidt33
Mar 15, 2015 07:20 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
