Fuel System Reconfigure After Motor Swap Quest:
Old May 24, 2003 | 09:10 PM
RabidDog24's Avatar
Question Fuel System Reconfigure After Motor Swap Quest:
Okay I am half/way done w/ my engine swap in my 95 Camaro. Where once was a 3.4 V6 is now the home of a 5.7 Liter mid 80's small block chevy.
My question is, how do I:
(1) Use the stock FI set-up fuel system for my 650 equip'd carb'd motor? The steel lines go to plastic near the front end. So basically I need to find a way to adapt the steel lines to carb lines.
(2) Restrict the fuel pressure in-line somehow?
(3) Make sure I get enough GPH to power the motor properly?
-Rabid
Old May 25, 2003 | 04:51 PM
RabidDog24's Avatar
TTT?
Old Jun 1, 2003 | 10:33 PM
Faccnator's Avatar
Rabid,
Unfortunately I do not have a good answer for you. But I am in the middle of a similar swap. I am putting a 350 (383 now) from a 71 Impala in my 95 3.4L Camaro. Is yours carbed? How did you fit it under the cowl. Also, what did you do with the distributor. Also, what do your motor mounts look like. I have an LT1 K-Member from the same year camaro and the motor mounts don' t match at all.
Faccnator
DirtyDaveW
Dec 1, 2016 05:37 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jul 4, 2005 05:00 PM
