Cam/Timing question
Old Dec 7, 2003 | 11:06 AM
MichiganSkip's Avatar
Cam/Timing question
1. What does a longer duration/lift cam do differently than the stock grind? (let a larger volume of air in basically?)
2. Why do we add timing on the low end when tuning for a long dur/lift cam?
TIA
Skip
Old Dec 7, 2003 | 12:37 PM
Black6SpdTA's Avatar
Re: Cam/Timing question
Skip
Without getting too technical, yes. The valves are open longer/more allowing more air/fuel into the cylinders.
Old Dec 7, 2003 | 12:45 PM
Okay, so we have more air/fuel coming in.
With a longer duration will the engine also suffer a loss in manifold vacuum?(at lower rpm,idle)
That's what I understand to happen. If that is the case, how does increasing the spark timing raise the rpm ? I know it does because I've seen it happen. I just wonder how it does it!
Thanks for the response
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
