A/C delete questions (obd2 need tune?, etc)
Old Feb 25, 2005 | 07:14 AM
pHEnomIC's Avatar
I have a 97 z28 with obd2. I was wondering whether or not it will need to get a tune if i get rid of the a/c system. I dont want it to throw codes.
Also, i think i know what im doing but does anyone have a link to an a/c delete guide?
Btw, does anyone know the cheapest way to bypass the system belt wise? I see the pulley goin for 50+$ and it just doesnt seem worth it. Is there any cheaper way?
Old Feb 27, 2005 | 10:07 AM
BadCo.'s Avatar
Re: A/C delete questions (obd2 need tune?, etc)
so does removing the belt from the ac free up horsepower...or is it the same as just cutting the ac off?
Old Feb 27, 2005 | 11:28 AM
pHEnomIC's Avatar
I think its more of a weight reduction. The a/c is heavy and mine is broken. It will cost more than it's worth to fix.
Old Feb 27, 2005 | 12:13 PM
There are a number of diagnostics for the A/C that will set the SES light.... system pressure sensor, temperature sensor, clutch circuit, etc. All of those need to be "programmed" out or you will get the SES light and/or stored codes.
Old Feb 27, 2005 | 01:42 PM
pHEnomIC's Avatar
Thanks guys. BTW, my a/c clutch seized up and the a/c doesnt work. I was wondering if i could just have the system drained and replace the compressor and be done with it after a fill or is there a lot more work to it?
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
k1996z28
Jan 21, 2015 07:22 AM
Jason Short
Jan 19, 2015 06:34 PM
cmdeshon
Dec 27, 2014 10:06 AM
