A/C delete questions (obd2 need tune?, etc)
I have a 97 z28 with obd2. I was wondering whether or not it will need to get a tune if i get rid of the a/c system. I dont want it to throw codes.
Also, i think i know what im doing but does anyone have a link to an a/c delete guide? Btw, does anyone know the cheapest way to bypass the system belt wise? I see the pulley goin for 50+$ and it just doesnt seem worth it. Is there any cheaper way? |
Re: A/C delete questions (obd2 need tune?, etc)
so does removing the belt from the ac free up horsepower...or is it the same as just cutting the ac off?
I think its more of a weight reduction. The a/c is heavy and mine is broken. It will cost more than it's worth to fix.
There are a number of diagnostics for the A/C that will set the SES light.... system pressure sensor, temperature sensor, clutch circuit, etc. All of those need to be "programmed" out or you will get the SES light and/or stored codes.
Thanks guys. BTW, my a/c clutch seized up and the a/c doesnt work. I was wondering if i could just have the system drained and replace the compressor and be done with it after a fill or is there a lot more work to it?
