Break in procedure
Old Feb 1, 2008 | 08:45 AM
cause4panic's Avatar
Break in procedure
Im not sure if this is a re-post or if it even belongs in advanced tech. But i guess break in is a part of engine building.
http://www.mototuneusa.com/break_in_secrets.htm
any comments? his article on smaller ports is pretty interesting too.
Old Feb 1, 2008 | 01:00 PM
Z-RATED94's Avatar
It has been posted before, but a reminder never hurts. After a short warmup period and oil and filter change, that is how I would do it.
Old Feb 1, 2008 | 01:14 PM
mdacton's Avatar
I just run the **** out of it, works great
Old Feb 1, 2008 | 05:49 PM
bombebomb's Avatar
Any there any truth to this? I know I read basicly the entire page, but im always up for the masses opinion.
Old Feb 2, 2008 | 09:38 PM
palehorse77's Avatar
Interesting Indeed. I'm getting ready to fire up mine so I'm curious to hear some the of the veterans Machinist / Builders chime in?? (mdacton no disrespect here intended at all. I firmly agree with your approach as a matter of fact!!)
My biggest question is about the ring pressure he mentioned. Does increase throttle apply outward pressure on the rings??
Thanks in advance.
Kirk
Old Feb 3, 2008 | 11:30 AM
Z-RATED94's Avatar
Thanks in advance.
Kirk
I believe that's the whole point, seat the rings.
Old Feb 3, 2008 | 11:53 AM
rskrause's Avatar
Moderator
Me too, in general terms. A little different for a flat tapppet cam and I do run it at ~2,000rpm until fully warm while looking for leaks, checking the timing, etc. Let it cool, take a good look and make sure it's good, check the valve adjustment, change the oil and THEN beat the **** out of it
One of THE best feelings is the first time you run a new HP or race motor.
Rich
93 RedBird
Nov 15, 2015 08:24 AM
Bxlt1
Sep 29, 2015 03:18 PM
War Engine
Aug 28, 2015 06:04 AM
Aug 17, 2015 09:50 AM
