fuel injection to carberator
Old Jan 29, 2008 | 10:25 AM
timestalker45's Avatar
i have a 92 camaro rs im getting a 350 bigg block crate i want to know waht mods can be done to a crate engine, and after its all finished i want to change from fuel injected to carberator and then put an air blower on top but I havent got the slightest clue where to start so i could use some advice
ps and i been looking at some five speed automatic transmissions has anyone got some good input as far as reliability and easy of installing?
Old Jan 29, 2008 | 12:01 PM
Probably posted in the wrong forum, but need more info to see where it belongs. Appears you have 3 different questions....
1. You want to know what mods you can do to a "350 bigg block crate". Are you sure its a big block? It would be unusual if it is. In order to know what mods you can make, you need to provide the full specs for the crate motor. If its basically a stock replacement setup, you might want to play with the heads and cam. If its already a "performance" build, your options might be a bit limited. In general, this question, along with the added info, would probably get the best results in "3rd Gen... Engine Tech".
2. You want to convert the crate engine from fuel injection to a carburetor, then add an air blower on top of it. Do you mean you want to add a supercharger (or turbo??), using a blow-through carburetor? Any particular reason for chosing a carb over fuel injection? This question would probably get the best results in the "Forced Induction" forum, although its a tough call. I suspect most people are running injected, not carbed.
3. You are looking for a 5-speed automatic transmission. You will need to provide info on the engine you are using. This would get better results in the "Drivetrain" section.
Old Feb 3, 2008 | 10:16 PM
Kraest's Avatar
Retired
Why is this thread even in this forum?
350 big blocks! Oh my!
Old Feb 4, 2008 | 08:18 AM
I tried to get that point across...... without actually saying it . Apparently I scared him off, which wan't my intent.
beltrunner
Apr 15, 2015 01:10 AM
Sauced
Mar 29, 2015 10:53 PM
Jubjub
Mar 19, 2015 10:23 AM
JurisAg02
Jul 27, 2002 11:49 AM
maddboost
Jun 11, 2002 02:47 PM
