BBC compresion heigth question
Old Nov 8, 2003 | 08:14 PM
Prorac1's Avatar
I am building a Big Block Chevy and need a piston with a comp heigth of 1.235. I found that JE makes a piston with a comp heigth of 1.245. Can i use this piston with a .041 felpro gasket or is the .01 going to give me clearance problems. Fwiw i am running open chamber Dart Pro 1s so i dont think piston to head clearance will be an issue (until we get into domes, lol) Thanks Prorac1
Old Nov 8, 2003 | 09:54 PM
rskrause's Avatar
Moderator
Re: BBC compresion heigth question
I've got no idea if you will have piston to valve clearance problems, but other than raising the CR, a deck height of +0.01" is ok. This is not uncommon. Some people feel that a small positive deck is beneficial due to a lower volume of combustion end product gaskets left in the cylinder. I don't know if this is valid, but I have heard it discussed.
Rich Krause
Old Nov 8, 2003 | 09:57 PM
Prorac1's Avatar
Thank you very much for the response. My major concern was weather or not having a positive deck heigth would pose any major problems, and it sounds like that wont be a problem. Thanks Prorac1
ChrisFrez
Mar 22, 2015 09:12 AM
1LEThumper
Jul 14, 2003 12:45 PM
BLUETOPTA
30
Sep 18, 2002 12:22 AM
Caps94ZODG
10
Sep 9, 2002 12:08 AM
80_OLDS454
Jul 20, 2002 12:03 AM
