Aftermarket fuel injection options
Old Dec 1, 2004 | 08:38 AM
dkeers's Avatar
Is there an aftermarket fuel injection setup on the market that can control 16 injectors (on a v8)? Did anyone use aftermarket engine management on the Lt5 vettes (they are the only production car I can think of that used 16 injectors that were controlled seperately) If so, where can I find out about it?
Dustin
Old Dec 1, 2004 | 10:30 AM
Boost It!'s Avatar
Re: Aftermarket fuel injection options
Dustin
Ford GT (the supercar) uses 16
Old Dec 1, 2004 | 12:25 PM
rskrause's Avatar
Moderator
The Electromotive TEC3 can control 16 injectors. Good source: www.kennedysdynotune.com
Rich
Old Dec 1, 2004 | 01:05 PM
dkeers's Avatar
Rich
Thanks. As far as I can tell, the TEC3 can only control 8 injectors (or 8 pairs of injectors that would essentially act like 8) since it only has 8 injector drivers. I need something more like the LT5 had where the two injectors on a cylinder can operate independantly. For example, only one of them runs when the fuel demand is small and the second set comes on like "secondaries". This is for a somewhat exotic application.
I didn't know that. Is there any good place to get the details of this car? It sounds awesome, but I haven't read much about it.
Dustin
Old Dec 1, 2004 | 04:24 PM
dkeers's Avatar
I just found this ecu from pectel: http://www.pectel.co.uk/sub_page.cfm...ucts/editID/16
Does anyone have any experience with it?
Dustin
Old Dec 1, 2004 | 10:30 PM
Highlander's Avatar
why not use a supefueler from carrolsupercharging??? it has 3 additionals that could help out.
Old Dec 2, 2004 | 12:55 AM
Boost It!'s Avatar
Dustin
we have a few at work. what do you want to know.
typical blown 5.4 rear engine car with an ugly stereo and wanabe race chassis.
****ing hell of a car for $125k though.
Old Dec 2, 2004 | 03:55 AM
1racerdude's Avatar
Call Electromotive and talk to them they can make their unit control anything you want to control.Have run 12 with their set up,the engine and 4 more.That was before they had big enough injectors to cover the HP and boost,but today that isn't the case,There are injectors that will cover anything EFI.16x100lb's will flow a ton of fuel.Got Pumps?????
Old Dec 5, 2004 | 11:15 AM
ASRoff's Avatar
Big stuff 3 will handle 16 injectors.
www.bigstuff3.com
It offers more features and costs less than F.A.S.T and Accel DFI
Old Dec 7, 2004 | 11:49 PM
Tweaked Zed's Avatar
I think FAST has an option to add extras too.
Jubjub
Mar 19, 2015 10:23 AM
cmdeshon
Dec 12, 2014 10:51 PM
Jul 4, 2005 05:00 PM
Brady
Jul 29, 2002 10:30 PM
