Single Plane Guys - PCV Question
Old Dec 23, 2005 | 08:01 PM
CMoney's Avatar
For the guys running single plane setups, what are you doing for crankcase ventillation? Adapting one to work? Running a vacuum pump (viable on a street car?)? Just looking for some input. Thanks.
Old Dec 23, 2005 | 08:28 PM
SStrokerAce's Avatar
Re: Single Plane Guys - PCV Question
Last one I setup used LT4 valvecovers and a line from the intake plenum.
Bret
Old Dec 23, 2005 | 09:06 PM
atljar's Avatar
I ran a breather in one valve cover, and a push in style PCV valve in the other. From the PCV ran a vacuum line to the intake.
I have since switched to just two breathers, i couldnt get the PCV to stop sucking oil.
Old Dec 23, 2005 | 10:38 PM
CMoney's Avatar
How long have you been running only breathers? I was leaning that way, but all the research I've done says that the PCV plays a big role in keeping the oil clean during light throttle conditions.
How much oil was your valve cover PCV valve sucking? I wonder if a small oil separator plumbed inline would work...
Old Dec 23, 2005 | 11:29 PM
atljar's Avatar
A few thousand miles. I change the oil under 3k miles with synthetic so i never really worried about long term effects.
I also ran without any evac system... bad idea. I had tons of moisure build up in the valve covers.
As for how much sucking? Not totally sure, but enough to coat the intake. Im sure a seperator or catch can would work, i just never cared to try and find out. I eventually planned to run the stock AIR pump as an ultra cheap vacuum pump, but never got around to that either.
Old Dec 24, 2005 | 07:33 AM
FASTFATBOY's Avatar
Was the valvecover baffled where the pcv was pushed in? If not, it needs to be to stop sucking oil.
David
Old Dec 24, 2005 | 03:40 PM
atljar's Avatar
It was the stock baffle on the passenger side
Old Jun 20, 2006 | 09:09 PM
Add on to this post. I have a distributor hole plug that has a provision for a PCV that is really trick. Thanks to OldSStroker.
Bret
Old Jun 21, 2006 | 06:42 AM
bdc95ta's Avatar
Bret
That sounds cool do u have any pic's Bret?
-b
Old Jun 21, 2006 | 11:47 AM
Not yet, but I can take one today. E-mail me about it.
Bret
Old Jun 22, 2006 | 05:26 PM
Black95Form's Avatar
Love to see it.
HectorM52
Jul 30, 2017 11:46 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
bossco
Nov 29, 2014 10:18 AM
Elcojoe
Nov 17, 2014 10:27 PM
Red97LT1
Aug 7, 2002 05:45 PM
