14:1 on pump gas?
Old Mar 1, 2005 | 11:14 PM
n20ta2's Avatar
14:1 on pump gas?
Im building a 420ci 1st gen for my 95 t/a and have a few issues I was trying to Iron out.I bought an eagle forged Rotating assembly from a buddy that has the 14:1 pop up JE pistons and was going to just mill off the dome untill i called JE and found out the dome is hollow.I dont want to shell out the 680.00 for a flat top so im stuck, is there any way to run this combo on pump gas? Here it is :Solid Roller cam has 771/780 lift 270/285 duration at .50, heads are the Brodix 23 degree cnc ported 68 cc 315@.600? Super Victor intake with 1000cfm holly dominator and msd pro billet distributer. I have heard of guys Mixing components with pump gas to yield higher octane levels and will go that route if needed. Im not running this thing around town to much just want to be able to drive it to the track and back and dont want to wast race fuel on it. If I can boost the octane and pull a little timing then when I get to the track I can fill up with 116,What are the components used to achieve this?
Old Mar 1, 2005 | 11:17 PM
Loony's Avatar
Re: 14:1 on pump gas?
Well you could always go with bigger combustion chambers, or thicker head gaskets to bring that number down. Plus that cam looks pretty big...so your DCR might not be that high and actually might work on pump gas...maybe. I don't feel like doing math so I'll let someone smart and not lazy do it
Old Mar 1, 2005 | 11:31 PM
1racerdude's Avatar
With that cam you must be wanting to shift at 8000RPM'S.With a 260ish cam on a 108* with 13.3 the DCR is 9.92 which is way to high for anything but 110 VP.You have to get your DCR down to 9.0 or a tad less to run pump gas with excellent cooling.
Do a search and find a calculator and figure your DCR and see. You don't want to go more than .040 on the quench to help prevent detonation,ie,no thick head gasket.
Go with fuel driving it to the track if it isn't a LONG way.
Old Mar 1, 2005 | 11:48 PM
Stephen 87 IROC's Avatar
You're never going to make a race engine like that live on pump gas unless it's detuned so much that it would be cheaper to just build a different engine. That's a bigger cam than what I have in my BBC race engine.
Keep what you have and convert to alcohol fuel.
Old Mar 1, 2005 | 11:54 PM
SStrokerAce's Avatar
Whats the ICL of that cam?
Whats the deck height at?
What's the gasket compressed thickness?
What's the Dome Volume on the pistons?
Bret
Old Mar 2, 2005 | 08:02 AM
n20ta2's Avatar
Im going to do a little research and get back to you sstrokerace.
Old Mar 2, 2005 | 12:46 PM
rskrause's Avatar
Moderator
Run it on methanol or race gas, but not pump gas IMHO.
Rich
Old Mar 2, 2005 | 03:06 PM
n20ta2's Avatar
It looks like thats going to be the only way.I guess its not all that bad as I dont drive it much,I just ordered a barrel of vp116 qnd it cost me 480.00 though!
Old Mar 2, 2005 | 03:07 PM
1racerdude's Avatar
Just thik thats 550-600 miles worth.
Old Mar 3, 2005 | 10:22 PM
sheppard00's Avatar
if you are friends with someone at a machine shop see if they will take the piston's back and swap them in on or for some that will better suit your needs
ad356
Apr 16, 2015 05:38 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
simple
Aug 11, 2002 11:56 AM
dmaastr
9
Jul 1, 2002 02:22 PM
