What is wrong with my engine?!?!
Old Apr 27, 2003 | 11:27 PM
Black91Z28's Avatar
Unhappy What is wrong with my engine?!?!
My engine is acting really wierd. When i start it up right off the bat the RPMS climb to 2,500 at idle. You would think after the choke kicks in or whatever, that the RPMs would drop to a more reasonable number but it stays at 2,500 RPMs constantly. It will idle like that for a while, then all of a sudden the RPMs will drop like crazy and my car will ALMOST die but not quite. When it drops in RPMs, smoke starts pouring out of my exhaust, and sometimes the smoke is black and sometimes the smoke is white. Not only that, but right when i start my car up, there seems to be a combonation of water/oil spurting out of the exhaust. The idle is really erratic, it will vary from 600 RPM to 2,500 RPM in a matter of seconds. It just started doing this last night as i was sitting in a parking lot talking to my friend. All of a sudden my car just died, so i started it up and it started doing this. I could barely get my car home. I'm sorry this was so long and not really in depth, but if u could plz tell me what the heck is wrong with my engine i would appreciate it!
Thanks guys,
Eric
Old Apr 27, 2003 | 11:45 PM
RedIrocZ-28's Avatar
Blown Head Gasket IMO
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
I'm not positive what liquid pouring out of the exhaust means but I know its bad. Im pretty sure its a blown head-gasket.
Old Apr 28, 2003 | 01:57 AM
thezisking's Avatar
The weird idling problem can also be cause by a bad Mass Airflow Sensor, but that doesn't explain the liquid coming out of the exhaust. Does your car throw a check engine code?
Old Apr 28, 2003 | 07:33 AM
irocz8957's Avatar
check your vaccum lines that could help with the idle a little bit!
Old Apr 28, 2003 | 09:13 PM
TheGreatJ's Avatar
Sounds like an intake gasket to me. The goofy idle would be due to the monstrous vacuum leak on just one or 2 cylinders, and the liquid exhaust could be coolant leaking into an intake port and blowing through. The high idle is probably the computer trying to keep it running so you can "limp home." A head gasket could do it too....run a compression/leakdown check and that'll tell you for sure.
Old Apr 28, 2003 | 10:32 PM
Black91Z28's Avatar
actually i took it in today and they put a new TPS (throttle positioning sensor) on it and reset it.....now it works perfect....go figure? cost me $75
ModdedNerd
Dec 18, 2014 10:52 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
Nostang 96z
Sep 15, 2002 10:15 PM
DarkHorse
Aug 3, 2002 10:17 PM
squirrels
Jul 13, 2002 01:58 AM
