What do I need to do with this swap
Old Mar 23, 2003 | 10:36 AM
lil305gta's Avatar
I am buying an lt1 cam from ebay. What additional parts do I need to buy to install this cam. What kind of gains in et, hp, and tq can I expect with my current mods? I also plan on putting in 1.6 rr and new springs.
Old Mar 23, 2003 | 11:03 AM
87DJP2001's Avatar
Gains- Not much, nothing to go with the cam.
Old Mar 23, 2003 | 11:09 AM
CODY BEHNKE's Avatar
It won't be worth the time of making the LT1 cam work in a LB9, you would be better off just using 1.6 RR.
Old Mar 25, 2003 | 08:34 PM
Striker27's Avatar
To be honest I think that would be a great a cam for your car. It has the worst cam you can get right now in it a peanut cam. With the exhaust upgrades you have done I think it will work extremely well. If I had a roller block that is the cam I would want to put in my car aswell. As for the rockers I really wouldnt bother to do it. The reason is I think you might run into some clearance problems with that cam and the 305 heads with the rockers. It is a better cam then what you have but isnt as good as an LT4 which would have been better.
Good luck you will be happy I think
Old Mar 25, 2003 | 09:08 PM
StealthElephant's Avatar
i put an lt1 cam in my 305, went from 15.5 to 15.3....the cam was free...thought i question if 25 hours of my life was worth .2 of a second when the 305 is coming out in the summer
Old Mar 25, 2003 | 09:20 PM
87IROC-Zowner's Avatar
StealthElephant...
What computer chip mods did you have to do to get the LT1 cam to run properly?
Old Mar 25, 2003 | 09:41 PM
TPI 305's don't have the peanut camTBI's do.
Old Mar 25, 2003 | 09:59 PM
my '87 305 TPI does... 190 hp factory rated
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
