gears
Old Mar 24, 2003 | 10:34 PM
STANGeatinZ's Avatar
gears(need help)
I was wanting to change out the stock 3.23 gears in my 85 trans am and was wondering if ya'll would recomend 3.73's.
thanks
Old Mar 25, 2003 | 07:23 AM
anyone, anyone?
Old Mar 25, 2003 | 07:30 AM
irocz8957's Avatar
i would actually take it a step further and go with 4:10's
Old Mar 25, 2003 | 06:17 PM
TheGreatJ's Avatar
4.10's with TPI??? Not unless you have a 6-speed, and even then it would require a lot of consideration. The TPI's powerband drops off pretty low and 4.10's would just take you straight past it. Coupled with the monstrous torque curve of a TPI system, 4.10's would create a lot of traction problems too. So in other words....all that's gonna do is cost you tires every couple of months. Not to mention destroy any thought of fuel efficiency.
3.42's are just about ideal....you can get away with 3.73's if you don't mind traction problems when it's wet and a bit less gas mileage.
Old Mar 25, 2003 | 10:35 PM
Thanks guys, but i've decided i'm going to stick with the 3.23's for now. When I do switch gears i'll prob. go with a 3.73.
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
