Tranny possibilities
Old Apr 21, 2005 | 07:14 PM
  #16
85_305's Avatar
Re: Tranny possibilities
Wow dude, screw that. Theres just too much work and money involved in that
Old Apr 21, 2005 | 08:43 PM
  #17
masiroc566's Avatar
Tell me about it!! If i knew then what I know now....Geeezz..i would have never bought this car or thought about the idea!!!
Old Apr 21, 2005 | 09:26 PM
  #18
85_305's Avatar
So.. what are my other options??? What about hopping up the tranny currently in it?
Old Apr 21, 2005 | 09:33 PM
  #19
85_305's Avatar
Is there a tremec that is a direct bolt-in for my '85? (preferably in 6spd form...)
Old Apr 21, 2005 | 11:58 PM
  #20
doug791's Avatar
EVERYTHING bolts up perfectly. The bellhousing fits fine. Also note that tremec sells and aftermarket version of the t-56 that will NOT bolt up perfectly, you need the t-56 out of an LT1 car. The wiring from the tranny is as simple as getting a new connector or two. And if you can handle a full tranny swap then dealing with your speedo is not a big deal.
The t-56 is a bolt in. Simple. No welding, No fabrication. It all fits. No manual will ever be easier to put in.
And no you cant beef up your t-5. Well you can but i already proposed that idea to a tranny builder assuming i could get a WC t-5 which you dont even have, and he told me not to waste my time.
If this is too scary for you i sugest you look more into the TKO 600. Your torque arm will bolt up perfect and you still need the aftermarket crossmember. If you buy the right Lakewood scattershield bellhousing whatever its called, its a bit pricey around 400 bucks but i am fairly certain you can use all of the t-5 stuff, minus needing a new clutch. And its got a mechanical speedo so it removes that headache for you
Old Apr 22, 2005 | 11:48 AM
  #21
85_305's Avatar
Are you talking about the Tremec bolting up perfectly or the LT1 T56?
Doug, you keep saying that an LT1 T56 is direct bolt-in, but look at that website masiroc566 gave me; there is a LOT of **** there that will have to be done.
Old Apr 22, 2005 | 12:15 PM
  #22
Z28SORR's Avatar
This is the absolute closest to direct bolt in you can get.
Go here and click on tremec. http://www.sallee-chevrolet.com/frame.html
Or go directly to the tremec site and look for "retroT56".
Old Apr 22, 2005 | 12:37 PM
  #23
85_305's Avatar
But it still says you have to dick around with shortening and moving and stuff.
Where could I find one of those, and for about how much?
Old Apr 22, 2005 | 01:42 PM
  #24
doug791's Avatar
I was saying that the t-56 bolts right in. But if you have all of the right components the TKO isnt any harder to install and has a mechanical speedo which atleast takes that headache away for you.
Ya i see everything he had to do in that link. Looks like just about everything you would have to do if you were pulling your stock trans/clutch/master cylinder and such and putting all of the stock stuff back in.
I think the only reason he pulled the engine was because he was putting a different engine in? Because thats definitly not necessary to do the swap. And other then a tiny bit of wiring stuff it just looks like a basic tranny swap to me.
This might be because the RETRO t-56 is still not the one used in the 93-97 camaros. That t-56 will bolt up perfectly with your stock torque arm and drive shaft, no modifications required.
Old Apr 22, 2005 | 01:57 PM
  #25
masiroc566's Avatar
Hi...ok..you can find a GM Tremec 3550 at Year One that will handle 425-525 ft/lbs torque capacity for $1750. The GM Tremec TKO rated at 525 lbs is $2059. Go to www.ddperformance.com they will have what your looking for there and may be able to help you with any questions....
Martin
Old Apr 22, 2005 | 02:19 PM
  #26
85_305's Avatar
Your saying that an ordinary T56 will bolt right in, but the more I looked around the more I found "you have to shorten your driveshaft" and "get a diff. torque arm" and "relocate this and that", and it is just getting so confusing
Honestly, I want an ordinary 94-97 Camaro T56; I could get one for pretty cheap I think (and all the accesories).
I can take out the mech. spedo in the dash, and put in an elect. one right? (I mean mount the elec. one right in the dash..)
Thanx for the link masiroc566, but I think using an ordinary T56 will be a little cheaper
Old Apr 22, 2005 | 02:33 PM
  #27
masiroc566's Avatar
I got mine for $1100. with the centerforce clutch...what a deal it was...it had only 22000 miles on it. look on ebay guy...u will find guys that want to unleash a good one for pennies....
Old Apr 22, 2005 | 02:44 PM
  #28
85_305's Avatar
^I've tried looking, I cant find ANYTHING TO DO WITH a LT1 T56, or 94 Camaro transmition, etc..
what search-words should I use
Now, say I get a tranny off of ebay, what will I need? The t56 bellhousing, clutch, and what else?
Old Apr 22, 2005 | 04:31 PM
  #29
doug791's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...969038987&rd=1
only 50 minutes left
Old Apr 22, 2005 | 04:56 PM
  #30
85_305's Avatar
NOOOOOO.. i wont have any money like that for at least a year or so, but that is a damn good price for a COMPLETE tranny that is fully rebuilt
Thanx for finding it though.
What search-terms did you use to find it?
