Rear-End
Old Sep 4, 2003 | 01:41 PM
TheBum167's Avatar
Rear-End
Will
summit part #: RMG-6901651
10-bolt, 8.5 in. ring gear, 4.10 ratio, ring and pinion set
Fit into an '82 camaro that currently has the stock rear-end
Old Sep 4, 2003 | 05:19 PM
Marc 85Z28's Avatar
Nope. That is for the older sytle 10 bolt, like found on the 2nd gen Camaro/Firebird and 80's Caprices.
You need gears for a 7.5" or 7.625" 10 bolt rear.
Old Sep 4, 2003 | 09:24 PM
Metaldrgn's Avatar
you probably wouldn't want 4.10 gears anyway unless you are a serious racer or have greatly larger tires. Most canaro's have a 2.74 ratio rear end (or at least all the ones with a 700-R4 in them and some of the manuals).
Old Sep 4, 2003 | 11:19 PM
TheBum167's Avatar
Ok thank u,
I was asking for a friend cause i got the 4.10's for my 78 trans am to replace the 4.56's that were in there, but now i'm not so i just wanted to see if he could make use of them...
R@mpage
Apr 20, 2015 10:02 AM
EddyZ28
Parts Wanted
Nov 14, 2003 03:58 AM
BitCypher
Aug 1, 2003 10:57 AM
GrdLockV6
Feb 11, 2003 06:59 PM
Marky82
Feb 6, 2003 03:25 PM
