Radiator Help... Big block
Old May 11, 2004 | 07:12 PM
1984camaroz28's Avatar
my car is running realy hot. just keeps climing past 220. Im runing the stock radiator.
Will this one do the trick
How much beter is this one then the other
Old May 11, 2004 | 08:41 PM
Dave89IROC's Avatar
the first one should do the trick, it requires very minimal modification to fit in a third gen, it can reuse the top plastic with minor trimming
the second is even better, but requires more work to fit, the top plastic will NOT work , it is 1 inch too short
Old May 11, 2004 | 08:46 PM
whats the stock 2row size tubes
Old May 11, 2004 | 08:49 PM
Dave89IROC's Avatar
1/2 in. tubes I think
Old May 11, 2004 | 08:59 PM
ok thank you....u think it will deff do the trick
Old May 11, 2004 | 09:01 PM
Stephen 87 IROC's Avatar
I used a factory 19x31 GM 3 core for a while with no problems. I converted to a Griffen for about a year just to try and reduce weight. When I converted to alcohol I took out the griffen and installed a rad from a Turbo Firefly.
The Griffen is nice but there's no drain on the rad. The only way to drain it is to pull the lower rad hose off.
Before you start changing the rad start checking other stuff.
Make sure the thermostat is opening all the way.
Make sure the antifreeze strength isn't too high.
Make sure the rad cap holds 15 psi.
Make sure the water pump is moving the coolent at the proper speed. Too fast and the coolent can't collect enough heat. Too slow and it can't pull the heat out fast enough.
Make sure there's enough air flow moving across the rad to pull the heat out of the coolent.
Have your rad checked to see if the core is plugged.
The GM 19x31 rads are plentyfull. They're a lot cheaper than having to buy an aluminum rad.
Old May 11, 2004 | 09:23 PM
it has a brand new water pump , thermo stat , how can i tell if it all working properly
Old May 11, 2004 | 09:38 PM
its a stock camaro radiator 2row pretty shure. like 1 year old. it ran fine with the small block. im runing 65% water and 35% anti
MadMav
Feb 6, 2015 11:02 PM
RedLineRev
Jan 23, 2003 03:51 PM
Eric H
Aug 10, 2002 06:39 AM
OutLaw305
Jul 26, 2002 03:47 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
