How do I take the fuel pump out?
Old Aug 26, 2004 | 01:33 PM
  #31
Ucantcme57's Avatar
Re: How do I take the fuel pump out?
Even my fathers 02 Cadillac Escalade EXT is pretty much alond the frame right under the drivers door, that's where mine in the tahoe is too.. My camaro is on the slanted floorboard part that is behind the rear passenger seats..
Old Aug 27, 2004 | 02:00 PM
  #32
MikeRock's Avatar
well its not the fuel pump or fuel filter, because gas flows freely through all of that, im wondering if maybe its an injector??? or if i just have a bad spark???
Would having a bad spark keep it from starting??
Somewhere between the uotput on the fuel filter and the engine something is happening.
Old Aug 28, 2004 | 12:37 AM
  #33
JJEXP's Avatar
just because gas flows freely does not mean that the punp isnt bad. You need to take find out how much pressure the pump is putting out. I did this a few weeks ago. My pump was only pumping at 6 psi when normal operating pressure is between 40 and 60 I believe. The car would starts ( sometimes...) barely idle and then die. Eventually we ended up pouring gas into the throttle body to keep it running while we drove it onto a lift.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
