head flow numbers?
Old Dec 13, 2004 | 01:25 AM
kandied91z's Avatar
head flow numbers?
anyone know where i can find intake/exhaust flow numbers for stock l98 heads, untouched fastburn heads and say a comparable afr head at a .60 duration??
Old Dec 14, 2004 | 05:03 AM
Sitting Bull's Avatar
Re: head flow numbers?
Stock L98s are about 190 cfm on the intake. Don't know anymore
Old Dec 14, 2004 | 11:36 AM
kandied91z's Avatar
thanks alot.. anyone else?
Old Dec 14, 2004 | 12:33 PM
angel71rs's Avatar
Chevy high performance has a head flowdatabase and I think they have some L98 aluminum heads listed. Look under tech articles.
http://www.chevyhiperformance.com/
Old Dec 14, 2004 | 02:29 PM
RedIrocZ-28's Avatar
AFR doesn't make a head crappy enough to compare to the 14101083 L98'ers.
Old Dec 15, 2004 | 01:51 AM
kandied91z's Avatar
well then show me where i can find numbers for their heads...ported or otherwise.
CHP seems like they were all very general in numbers on the intake/exhaust side using .6 as a bench.
hmm..
Old Dec 15, 2004 | 07:19 AM
Damon's Avatar
CHP numbers are VERY specific with data from .050 up to .600 and everything in between, plus information on their flow testing regimen including exhaust flow both with and without a header tube.
They tested the ALUMINUM L-98 heads (like used on the Vette) but not the cast iron L-98 heads (used on F-body cars). They're different animals. But neither is anything to write home about, flow-wise.
I don't beleive they tested the Fastburn heads, but they did test several different AFR heads.
Old Dec 15, 2004 | 07:26 AM
Damon's Avatar
BTW- I put all the CHP flow numbers in an Excel spreadsheet for easy viewing/comparison. If anyone wants a copy just shoot me an email.
Old Dec 15, 2004 | 12:13 PM
f-bodybuilder's Avatar
__________________Intake_________________________E xhaust
Lift______.100 .200 .300 .400 .500 .600______.100 .200 .300 .400 .500 .600
CFM_______44 101 155 182 196 202_______41 82 125 137 140 141
These are the numbers for stock 083 L98 heads straight from TPIS.
Old Dec 15, 2004 | 05:25 PM
LT1Powered85Z's Avatar
Don't mention TPIS, cause Jeff will instantly disregard any related information.
But those numbers do look pretty accurate. Can't fault TPIS when testing stock products, can 'ya? I'm sure Jeff can/will find a way.
Eric
Old Dec 16, 2004 | 06:45 PM
AutoRoc's Avatar
http://chevyhiperformance.com/techarticles/41598/ Scroll down to the "sidebar" articles. Huge information right there on probably 30 different SBC heads.
I've never seen Fastburn numbers other than GM's BS claims and I've spent way too much time looking.
AFR has their own numbers on their website.
Old Dec 17, 2004 | 03:41 AM
kandied91z's Avatar
yeah what gm claims and what fastburns make, particularly on their own are far fetched all together. speaking of which go clear your pms at MM.
DirtyDaveW
Dec 1, 2016 05:37 PM
parkers Z28
Mar 11, 2016 08:14 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
ModdedNerd
Jan 29, 2015 07:23 PM
