harmonic balancer question
Old Feb 19, 2003 | 04:55 PM
jayman350's Avatar
I noticed towards the end of last year (last time i drove my camaro) that it would shudder as i was driving along, always the same speed and rpms so i knew it was coming. the car would feel a little "off" when it was doing it and my y-pipe would bang on my SFC
well i looked at my harmonic balancer and the rubber ring that connects the inner and outer rings was missing some of the rubber..... i have a feeling that this is what is causing my vibrations
I have a parts car that i'm ripping out the rear end, trannie, all the 5 speed stuff, and pulleys (as well as some other stuff like an A/C delete firewall)
I'm gonna have the engine out in the near future and i was wondering if i could use the balancer from the 305 on my 350 Its not really a high HP car (yet ) so i was hoping that just replacing it with another stock one would suffice, as opposed to buying one of the aftermarket ones that have quite a price range.
I haven't had a chance to measure what the sizes are for both balancers, but assuming that they are both the same could i use it? could i use it even if its not the same? if i need to buy another one should i just get like the summit one for $50-ish and just get the same size?
I'm on a limited budget of nothing so if i could get this part from my donor car it would be awesome
thanks
Old Feb 19, 2003 | 06:16 PM
Dave89IROC's Avatar
I have used 305 balancers/dampers on 350's before and had no trouble, I say try it and if all is well, OK, if still has a vibration, then spnd $ and get the summit one
Old Feb 19, 2003 | 07:44 PM
MRZ28HO's Avatar
Thumbs up
Since your car is an '85, I would image you have a 2-piece RMS type block, correct? All SBC from '55 to '86 use the same balancer. The engine is internally balanced, so the balancer is un affected. Some high performance SBC used the larger 8" damper, but all the others used the 6-3/4" damper. So long as it is good, go for it.
Old Feb 19, 2003 | 07:46 PM
TheGreatJ's Avatar
You can use it. I had the balancer from my old 305 on my 355 for a year and a half (till the ring broke and I bought a Fluidampr.)
Old Feb 20, 2003 | 12:01 AM
jayman350's Avatar
the 305 is an 85 but my 350 is 86 and up w/ the centerbolt heads
thanks for the info guys, now i just have to get around to doing it..... oh well, spring will be here soon enough and then all the work from this winter will pay off
DirtyDaveW
Mar 15, 2015 07:01 PM
Red_94Formula
Mar 7, 2015 09:21 AM
Newgmman
Feb 25, 2015 02:53 PM
cyteone
Feb 7, 2015 06:04 PM
smokin5s
Jul 24, 2003 10:47 PM
