Engine Swap
Old Jan 26, 2005 | 11:20 AM
83' Z28 CAMARO's Avatar
Engine Swap
Hey I Was Thinking About Swapping The 305 Out Of My 83z' For A 350. But I Would Like To Use The Original Cfi, Is This Possible? What Kind Of Job Would It Be? Anything You Could Tell Me Would Be Great! Thanks!
Old Jan 26, 2005 | 03:44 PM
five7kid's Avatar
I've heard of guys putting 350s and even 400s under CFI. Apparently the stock intake manifold is restrictive but basic porting work helps it out.
Otherwise, I'm not up enough on CFI to provide any more details.
Old Jan 27, 2005 | 10:24 AM
kbog54's Avatar
Re: Engine Swap
Hi, i happen to own the same car as you, does yours have the fujtional hood scoops?
Anyways, alot of people will tell you not to waste your time messing around with your crossfire injection- what you are thinking about doing is definately possible, GM used the same tbi's and intake on both the 305's and 350's. however if you swap the intake over to a performance engine vs. a more stock one, you will have flow issues that can only be addressed by porting the intake and throttle bodies.
Here are a few cfi specific sites :
http://www.crossfire.homeip.net/
http://www.thirdgen.org/techbb2/sho...threadid=190137
http://www.technovelocity.com/chevyhackers/
also, get in contact with mrr23.
good luck
Old Jan 27, 2005 | 01:36 PM
CtRw's Avatar
Re: Engine Swap
I said screw CFI and put a LS1 in.
Old Jan 27, 2005 | 11:47 PM
Re: Engine Swap
Ya, Mine Has The Functional Hood Scoops Too. I Just Thought It Would Be Pretty Cool To Have A 350 In It But Still Look Stock. Does Anyone Make After Market Hi-performance Cfi Intakes?
Old Jan 28, 2005 | 01:31 PM
CtRw's Avatar
Re: Engine Swap
Nope.
Old Jan 28, 2005 | 01:34 PM
km9v's Avatar
Re: Engine Swap
Screw the 350, do a 427!! Go big or go home!
Old Jan 31, 2005 | 12:09 PM
kbog54's Avatar
Re: Engine Swap
Yes, there is an aftermarket intake for CFI www.x-ram.com
I did the same thing as you, and granted, as im sure many people will tell you on this board, i could have had a faster car for less, blah blah blah.........
But i had the satisfaction of making a car fast that no-one expected to be fast at all.
You will make much more power more easily and cheaply if you switch to a ddifferent intake, but if that isnt what you are after, then make the CFI fast.
check out some of those sites that i posted, they will be able to help you alot more without the bashing that you will get around here.
Old Feb 1, 2005 | 09:20 AM
Re: Engine Swap
Hey Thanks Alot I'm Going To Check Out That Intake Right Now!
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 12, 2014 10:51 PM
Cam28_boy
Aug 6, 2002 08:40 AM
