Engine Oil Help, What is good for a Flat Tappet Cam?
Old Nov 18, 2012 | 01:31 PM
BLACK Z !'s Avatar
Hi, i was wondering what is a good oil to run with a Flat Tappet cam, I run Mobil 1 or Amsoil in my cars/Bikes/quads and so on.
I am looking for a Oil in 10W30 to run in my Z28 that has a 350 and a Flat Tappet Cam,
These are the ones I am looking at
What are the Differences between the two Royal Purple ones?
Royal Purple Motor Oil 01130 - SummitRacing.com
Royal Purple HPS Street Motor Oil 31130 - SummitRacing.com
Why does this one say racing only? is a emissions thing?
Lucas Racing Only High Performance Motor Oil 10610-1 - SummitRacing.com
Here are some more, Thanks
Motor Oil - Synthetic Oil Type - 10W30 Oil Weight - ZDDP Enhanced - 1 qt. Oil Volume - SummitRacing.com
I think I can get Quaker state at the local Napa.
Old Nov 26, 2012 | 10:22 PM
quickchicken's Avatar
Re: Engine Oil Help, What is good for a Flat Tappet Cam?
Comp has an oil thats intended for race apps and flat tappets, shell rotella t is another thats recommended for flat tappets. you want something with additives unlike reg 10-30 that dosent have them.
Old Nov 27, 2012 | 06:38 AM
BLACK Z !'s Avatar
I may go with the Amsoil Z Rod Oil. What do you guys think about that?
Old Nov 30, 2012 | 11:24 PM
AutoRoc's Avatar
A few VW racers(flat tappets) in the family run Joe Gibbs stuff with high zinc or Brad Penn..
They used to run Valvoline VR1 and some racers still do. Sometimes you can find it for $1.99 or 2.99..
"specialty" oils just keep going up in price it seems.
Tons of people swear by Rotella T and VR1... I'll never do a flat tappet again after having 2 Comp Nitrous HP cams wiping lobes out on break in.. ruined a brand new engine.. Comp offered no help.. The first cam wiped 1 lobe... ordered the same cam again... that one wiped 5 lobes off!! Springs were Comp spec for the cam too..
Goodluck!
Old Nov 30, 2012 | 11:30 PM
how did you break the cam in, were you using dual springs and did you break the cam in with the inner spring in place if you were using dual springs ?
Goodluck!
rideordie
Nov 5, 2019 04:52 PM
oldschool
Feb 9, 2016 09:21 PM
PCLZ28
Dec 24, 2015 05:19 PM
Noenav
Dec 6, 2014 07:35 PM
Jul 4, 2005 05:00 PM
