distributor problem?
Old May 6, 2004 | 01:47 AM
kandied91z's Avatar
can't seem to keep the thing tight.....after a day or two i go out to start the car and my timing is off again? any suggestions?
Old May 6, 2004 | 11:09 AM
Pneumatic_Tire's Avatar
inspect your hold down screw, and bracket, maybe even try running a tap of the same size down through the screw hole in the intake. If that dont work, try some semi permanent thread locker.
Old May 6, 2004 | 08:18 PM
BOTTLEDZ28's Avatar
I second that. also, The hold down clip has a curve to it, It is suppose to be installed a certain way I believe. I cant rememeber which way though and my car is in 2000 pieces so I cant go check. Try turning yours upside down and see how it grips the lip on the shaft.
DirtyDaveW
Dec 1, 2016 05:37 PM
greenzee28
Mar 26, 2015 09:13 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
brentbrowning01
Dec 3, 2014 10:36 PM
