Code 44 Oxygen sensor
Old Apr 28, 2003 | 04:46 PM
1990Iroc_Z's Avatar
Ok I got a code 44 on the scanner, lean oxygen sensor. So I bought the o.e. replacment, and it's still coming up. What should I do next?
Old Apr 28, 2003 | 06:57 PM
mrr23's Avatar
lean exhaust is many things. fuel pump giving out, header gasket leak, vacuum leak, etc.
Old Apr 28, 2003 | 07:01 PM
1990Iroc_Z's Avatar
yeah the service engine soon light will come on and then go away? I hope it's not the fuel pump.
Old Apr 29, 2003 | 09:03 AM
Error's Avatar
Check the cable/wiring. Did you reset the computer? Have you checked the other O2 sensor? (isn't there one on the manifold?)
Old Apr 29, 2003 | 08:09 PM
aklim's Avatar
Should be on the driver side exhaust manifold.
I'd spray around the hoses and seal areas with brake cleaner to check for air leaks. That or use a propane torch without it being lit. Also check fuel pressure. Get a scanner and try see what the ECM is reading including the air temp and coolant temp.
Old Apr 29, 2003 | 11:13 PM
1990Iroc_Z's Avatar
coolant temp is fine same with air temp, I guess I just reset the computer and see what happens.
Old Apr 30, 2003 | 07:33 AM
irocz8957's Avatar
i had the same probelm except my code was 34 are you sure you got the right probelm?
Old Apr 30, 2003 | 10:41 PM
1990Iroc_Z's Avatar
yeah I got the snapon scanner code 44 is lean oxygen, it's only half working so i replaced it.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
91Bird305
Aug 5, 2002 01:39 PM
ZZed
Jul 31, 2002 10:31 AM
Brian Wheeler
Jul 26, 2002 03:14 PM
busta9876
Jun 28, 2002 02:22 PM
