Can I do this? Will it work?
Old Sep 7, 2004 | 12:16 PM
  #16
87DJP2001's Avatar
Re: Can I do this? Will it work?
I went from A 305 Stock TPI to a crate 350 and used all the TPI parts. In addition to these which are needed on a 350 TPI:
1) 22# fuel injectors
2) Knock sensor for a 350
3) New Chip for the ECM (requires data for 350)
I also upgraded the runners and added headers,but are not required. Everything else will work with no problems.
Old Sep 7, 2004 | 04:08 PM
  #17
87DJP2001's Avatar
Originally Posted by robvas
You might want to look into a custom chip of some sort as well, especially if you're got other mods ...
Some advice, use a stock GM chip first (1988 is a good one) to get up and running. After everything is set then think about a custom chip. Don't start with a custom chip because you will have a unknown varible with one.
Been there, Done it and its running.
Red Hawk 94
Mar 18, 2019 04:03 PM
blac94Z
Feb 18, 2015 11:36 AM
squarehead
Jan 15, 2015 07:02 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
