9" Borg Warner on stock 88 IROC-Z?
Old 09-20-2002, 12:58 PM
  #31
88 427 Camaro's Avatar
What I can't help but wonder is why GM discontinued it in 1990
Cost was the primary reason. Hence the slight (but nowhere near enough) improvements to the 10 bolt.
Miles
www.9bolt.com
88 427 Camaro is offline
Old 09-28-2020, 04:24 PM
  #32
1badcj8's Avatar
Re: 9" Borg Warner on stock 88 IROC-Z?
Ok so this is an old thread I see but some places like it if you reply to something rather than starting a new thread.
Anyway, I have an '89 IROC with the G92, yes it's got the 9 bolt and 3:27's. BUT I want them a bit lower. Not 4:10s or 4:11s mentioned here. Maybe - 3:70s but not lower.
What I need to know is will my current carrier be fine with the lower gear set? And is the other mid 3:xx's that were not stock options ie 3:55s??? Yes my gears and carrier are good to go.
Thanks a bunch...
1badcj8 is offline
Old 09-28-2020, 05:54 PM
  #33
According to DTS the carrier break is 3.07 and numerically lower / 3.27 and numerically higher.
https://www.drivetrainspecialists.co...t-borg-warner/
Just to clarify, the rear axle ratio is expressed as 3.27:1 (3.27 rotations of the driveshaft for each wheel revolution), not 3:27
Injuneer is offline
Old 09-28-2020, 07:08 PM
  #34
1badcj8's Avatar
Yep I got ya, I know that just a punctuation error
Anyway - Thank you, I'm going to check that out. Hopefully it will tell me if a3.70 set will ride the same carrier...
I see it now, its a sales site not an info site... I have already found a number of places like that... Need exact info then I'll buy from some where, thanks for the try again just the same, just not what I'm looking for...
1badcj8 is offline
Old 09-29-2020, 07:32 AM
  #35
1badcj8's Avatar
This I found to be interesting.
Hi Dan,
All the 9 bolt ratio are: 2.54, 2.77, 2.92, 3.08, 3.23, 3.27, 3.45, 3.50, 3.70, 3.73, 3.89, 3.91, 4.10, 4.11, 5.13.
Some of them are pretty rare, but that's all of them ever produced.
Cheers, Glenn9Bolt.com
1badcj8 is offline
Old 08-18-2021, 12:01 AM
  #36
laneracing's Avatar
I have a 9 bolt for sale with disk brakes all there with posi sway bar and shocks just taken out of a iroc call 319-310-4155
laneracing is offline
Old 08-18-2021, 06:35 AM
  #37
Please post for sale items in the correct Marketplace forum.
Injuneer is offline
jasonwinn
9
09-18-2005 08:10 PM
SLW LT1
11-12-2004 07:18 AM
QCKZ28
01-07-2004 06:42 AM
irocz8957
04-13-2003 08:46 PM
Rage
11
09-27-2002 05:38 PM
Quick Reply: 9" Borg Warner on stock 88 IROC-Z?
