thinking about changing form a 9bolt to 10bolt
Old Apr 13, 2003 | 08:02 PM
irocz8957's Avatar
Thumbs up thinking about changing form a 9bolt to 10bolt
i have been calling places all around the u.s trying to get prices on how much it would cost to get a new set of gears for my 9 bolt and it's looking to cost about $1000 that i thinking about buying a used 10 bolt with a 3:23 gear or higher. Of course i would still keep my 9-bolt just in case anything were to happen to my 10-bolt, does this sound like a good idea???
Old Apr 13, 2003 | 08:04 PM
irocz8957's Avatar
also i was wondering if i got a used 10-bolt out of a camaro would it just bolt right up or would there be anything i would need to know before putting one in?
Old Apr 13, 2003 | 08:10 PM
IROC5.7TPI's Avatar
The rear ends are direct bolt in swaps, however the 9 bolt is much stronger and more reliable then any 10 bolt. You can get parts for them at www.9bolt.com (or it might be www.9-bolt.com )
If you want proof of the 9 bolts holding up look at the 89 TTA. They are making big power and hardly ever break rear ends and they have 9 bolts with 3.27 gears.
Old Apr 13, 2003 | 08:46 PM
TheGreatJ's Avatar
www.diffsolutions.com is the same company as 9bolt.com and carries new gears for the 9-bolt rear at around $300/set. Installation will cost you $100-200 additional. You can probably get a 10-bolt with the gears you want for $300, and it will bolt right in, but it is definitely a weaker rear. However, if you aren't gonna be running more than around 400hp the 10-bolt should be just fine.
If you do decide to swap in a 10-bolt, do you wanna sell your brakes? I need some '89 brake hardware for my 9-bolt...
DirtyDaveW
Dec 1, 2016 05:37 PM
PCLZ28
Dec 24, 2015 05:19 PM
meissen
Jun 1, 2015 07:59 AM
YellowTransAm350
Mar 2, 2003 03:38 PM
