86' Firebird engine swap, 2.8 Ltr to 305 H.O.
Old 06-10-2010, 11:27 AM
Dodge99's Avatar
Question 86' Firebird engine swap, 2.8 Ltr to 305 H.O.
My brother and I are working on an 86' Firebird, it had a 2.8 Ltr V6 in it, mated to a 700 R-4, we want to put a H.O. 305 in it and use the 700 R-4. My Questions are, first will the original fly wheel work in this setup? Second , what do we have to change to make this work? Plz. Help , any advice or tips would be greatly appreciated.
Dodge99 is offline
Old 06-12-2010, 06:25 PM
patstoy's Avatar
You will not be able to use the 2.8 transmission with the 305, it has a different housing. You will need a V8 transmission. As to what else you will need to change, it is basically everything from the radiator back to the driveshaft, along with the computer, tach and fuel pump. Thirdgen.org has numerous write-ups in detail on the swap.
patstoy is offline
Old 06-12-2010, 07:38 PM
Dodge99's Avatar
Hello patstoy ,
Thank You for your input , which transmission would you suggest?
Dodge99 is offline
Old 06-12-2010, 08:03 PM
patstoy's Avatar
I would go with a V8 700-R of the same period as your car. I believe your bird's speedometer is cable driven. Later years are VSS which would require changing out the dash pod. Not a bad job, but a cable driven would be an easier swap. I know Camaros have cable thru 1988.
If you are going carb, you would need to wire in the lock-up on the converter.
patstoy is offline
F'n1996Z28SS
08-23-2023 11:19 PM
cmdeshon
01-04-2015 11:15 AM
cmdeshon
12-12-2014 10:51 PM
305fan
06-27-2002 09:44 AM
Quick Reply: 86' Firebird engine swap, 2.8 Ltr to 305 H.O.
