Frontal shot of new Camaro......
Old Jan 12, 2008 | 01:26 PM
  #151
5thgen69camaro's Avatar
Originally Posted by Big Als Z
Ive tried to match the best picture of the concept to this picture
Not too much of a difference
Thank You! I dont completely agree though. I think the preproduction is ALOT better than the concept! Im definatly a 69 camaro guy. The Preproduction changes the braces grill the concept had for one more true to the 69 which is much better looking. It looks to me like the greenhouse was moved forward. Please tell me this doesnt put the engine back under the windsheild as this is a definate deal killer for me unless that engine is accessable after my 4th gen 3.8. Im sure its not. This seems to make the preproductions hood slightly shortened, and its trunk wich was an odd shape and tiny is now bigger and more realistic. A welcome change in looks to my eye and I hope trunk space. The black around the foglights give them depth. The concept was way too wide for me. It was also hard for me to judge it fairly with the goofy 21 and 22 inch wheels pushed into the fender wells. I think its width to hight ratio made it look odd. All of which hurt its proportions and look for me. One of my early complaints was it could use the 69s wheel well lines. The low door lines of the concept and preproduction give it its own charachter. Theyve changed my mind. especially since the 1st gens and early muscle cars body rolled under at the bottom. The newer cars go straight down. It gives somewhat of an appearnce of rolling under rather than being flat. I dont like the concepts parking lights in the grille as they hurt the blackout look of the headlights being pushed in. Seeing the front of this mule was an unexpected if only a temporary treat for me. I know its getting the concepts or better yet bumblebees headlinghts and parking lights. but this shows the possiblities of what could be. Maybe a proportionate headlight round or bumblebee headlight. Maybe a small dash blinker to the inside like the mule with a slightly larger dash to the outside of the headlights that idealy could go black when not on. Im not sure. I dont like to critize without offering an alternative but Im not sure I have one. Im hoping the camaro emblem doesnt make it to the exterior.
Please integrate that antenna into the back window, pass mirror or something. also can the gills be functional at all? If not theyre fine.
Old Jan 12, 2008 | 01:44 PM
  #152
Dale88's Avatar
Looks great so far!!! They are really killing me with these pictures though - look here's a badass car you wont be able to buy for a few more years
Old Jan 12, 2008 | 01:54 PM
  #153
ronssito's Avatar
Originally Posted by Gripenfelter
Is that front facia ram air opening functional? Or is it just a moulding? Just want to know if I should go out an buy a sawzall or not.
Old Jan 12, 2008 | 02:09 PM
  #154
Bob Cosby's Avatar
Originally Posted by 1fastdog
Right you are... to a great extent.
I got extra lucky at one point when I had the lucky pleasure of having the fellow that does many < maybe most > of the calibration work on V-8 motors for GM stop by my house for a look at my Z06 to review a couple of things I had noted in Florida heat and humidity. < GM has/had a test area a couple of hours from my house >
He came by in a "mule" and accompanied by a chase car/driver with telemetry goodies. < If I seem to be wandering, there is a point here.. >
IAT temps "rule the roost" when it comes to timing advance, air-fuel, etc.
< so does cat overtemp but that's for a different thread. > Nonetheless he showed me on the computer screen how it is.
CAI doesn't help much if the vehicle is static, such as sitting at a light/tree... however, even a cold air mod such as the last gen Corvette Z06 front fascia screens drop the temps at the IAT sensor temps much faster than if the screens were closed like the C5 coupe and 'vert.
I have found that the gold plated foil < think metallic contact paper > used in roadracing DOES retard IAT temps rising if the vehicle is at a static state as well as mitigating the heat transfer from the buildup of under hood temp transfer under roadraing conditions.
In conjunction with CAI/airflow smoothing mods, the timing retard and richening protections don't insinuate themselves nearly as much.
I use the stuff myself, which may be strictly anecdotal regarding what I have seen on the computer readouts, but I also have noted that every Corvette roadracing team I interface with use it as well. They don't agree on the pre-throttle body plumbing... but they all agree on this stuff.
As with many things, this might be an example of using multiple solutions to resolve one issue.
That's a good read. Of note, we typically set the timing at a static setting for WOT, so I never had to worry about the computer retarding it due to IAT readings. Also, I would suggest it is almost certain that results would be car specific, and highly dependent upon the type of stock setup, as modified by whatever you ended up with (location, number of bends, type of material, etc).
As an FYI, my logging was all done with an Autotap tied to a PDA. This allowed me to monitor most computer inputs real time, and also log most parameters.
Anyway....as stated....good read!
Bob
Old Jan 12, 2008 | 03:06 PM
  #155
jgenestra's Avatar
Thumbs up
Hello,
I think the preproduction Camaro looks great and the entire Camaro team has done an awesome job!
Old Jan 12, 2008 | 03:17 PM
  #156
CLEAN's Avatar
Originally Posted by Doug Harden
Here's a crew of knuckleheads....
I guess I'm honored not to be included as a "knucklehead" even though I'm hiding in there too. I was blocking for Mom Settlemire.
Old Jan 12, 2008 | 03:36 PM
  #157
hyperv6's Avatar
Originally Posted by Bob Cosby
"Cold air intake" (CAI) is certainly more proper than "ram air", though I understand the marketing by calling it the latter.
Of note, in my testing/data logging (obviously on other vehicles), I've found that CAI's typically don't reduce the IAT reading near the TB much at all. Perhaps a little, and perhaps under certain circumstances, but not across the board. Still....so long as the opening is actually open, I'm fine with it (personal opinion).
Concur. IMHO, straightening out the airflow is the most important part.
Bob
That is all KNN intakes do is clean up the flow in and not have to worry about noise. The factory boxes are very ristrictive.
My 3800 SC gained 15 HP with just an intake and filter. Plus it sounds cooler now.
I think that is all GM is doing with the from mount intakes as it is cooler and easier not to bend the intake as much as if you will note ont he new ZR-1. it is much more direct vs what wh had on the last Camaro SS hood intake.
Old Jan 12, 2008 | 03:43 PM
  #158
72 Z27's Avatar
Looks really good...can't wait to see more production like headlights.
Old Jan 12, 2008 | 03:59 PM
  #159
1fastdog's Avatar
Don't sell taking care of Scott's Mom short my friend. You get a special seat in GM heaven for such things.
Old Jan 12, 2008 | 04:08 PM
  #160
krazzycowgirl's Avatar
LOL The gal in the glasses
is one of our club members lol.
Old Jan 12, 2008 | 04:14 PM
  #161
Black5thgen's Avatar
Car looks great, I hope we get a front and center shot to judge how wide it is.
Old Jan 12, 2008 | 04:45 PM
  #162
UHP-CAMARO's Avatar
Dam! Scott's Mom is in your club? Now how cool is that?
Old Jan 12, 2008 | 04:47 PM
  #163
No that isnt scotts MOM. that is a friend of his that lives here in Washignton state lol.
  #164
CLEAN's Avatar
The lady in the picture isn't Scotts mom. If you go back to the wide shot, on page 8 I think it is, I'm on the right side w/ the dark red shirt and tan jacket, Mom Settlemire (her hair anyway) is over my right shoulder.
Old Jan 12, 2008 | 04:48 PM
  #165
I am talking about this pic, The gal that is standing behind the guy that is infront of the LS2(?) is one of our club members NOT scotts MOM.
