94 camaro vats problem
Old 04-15-2014, 03:53 PM
S Leger's Avatar
just changed the ignition in my sons 94 camaro, the wires on the old ignition were broke, We installed a new ignition and got a new vats key, the car will turn over for a second ,then act like the vats keys isnt reading, the car will not turn over, then it will act like its working, it will turn over for a second but not start, repeat. i am wanting to bypass it{vats}, i checked the ohms reading on the key pellet and get 601, is this right? all charts i see do not show a 601 reading as an acceptable one? is my issue not the vats pellet ? thanks for ANY HELP
S Leger is offline
Old 04-15-2014, 05:45 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Re: 94 camaro vats problem
Are you sure it isn't reading 6.01K ohms (6010 ohms)? That would be a valid value. Nobody could have made you a key for 601 ohms. The ignition switch has nothing to do with the VATS value. That information is only stored in the VATS module or BCM if a newer car.
GaryDoug is offline
Old 04-15-2014, 06:27 PM
S Leger's Avatar
yes, its is 6.01k i was reading on a 20 k ohm scale, i believe it is the ignition switch on the steering column, will try that,
S Leger is offline
Old 04-15-2014, 08:43 PM
Prominent Member
GaryDoug's Avatar
As I am sure your know, the mounting hole slots on the switch are long, allowing a lot of adjustment. It may just need to be adjusted to be sync with the key lock. Trial and error is probably your best bet here.
GaryDoug is offline
Red Hawk 94
03-18-2019 04:03 PM
bernie1951
12-10-2014 10:03 AM
siguy
11-27-2014 10:07 AM
Fedesna
11-23-2014 11:06 AM
Chrisdude
07-24-2002 02:25 PM
Quick Reply: 94 camaro vats problem
