OIL weight
Old Nov 15, 2007 | 02:00 PM
cmzfly93's Avatar
OIL weight
fresh 355 .0023 clearences on mains and rods what oil should i be running in 60-100 degree temps. When should i switch to synthitic i have about 1000 miles on it still smokes a little under full throttle just a little but ring gaps are at .023 is that normal for 10 psi of boost and forged pistons to use a little oil or are rings not all the way seated 9.3 compression 165 psi in cylinders with a cam 224/236-114 hellfire rings also
Old Nov 15, 2007 | 03:44 PM
ramair96ws6's Avatar
what did your engine builder suggest?
Old Nov 15, 2007 | 08:55 PM
rskrause's Avatar
Those are TIGHT clearances. Run a THIN oil, for sure.
Rich
Noct
May 26, 2016 10:26 AM
carguy0119
Apr 11, 2016 11:11 PM
cmsmith
Apr 10, 2015 10:03 AM
F550maranello2
Apr 1, 2015 11:10 AM
NEWBIE T/A
Jun 14, 2002 12:27 AM
