What flex plate???
WD
You realize that this is not an LT1 specific piece but is generic? If you have stock rotating assy., you can buy a flexplate that is a simple bolt on as it is already balanced against a stock bob weight. If it's for the combo in your sig, which looks like a non-stock setup, it is going to need to be final balanced. You probably already know this, just pointing it out to those reading who think the piece would be a simple bolt-on.
Rich
Rich
Rich
Rich
oooh happy day!!!!!!Steve
Rich, whenever you have something to say I am all ears. Over the years you have tought me alot about these cars. My motor has a stock crank, with forged Speed Pro pistons. I need the flexplate for the Machine shop. This weekend they are going to get everthing I have to assemble the long block.
Steve
A "generic" flywheel like that will usually have a large balance weight. The machine shop will balance it against your specific assembly by drilling shallow holes in the weight to remove the necessary amount.
Rich
