Tranmission
Old Nov 19, 2002 | 12:46 AM
383 N20 TA's Avatar
Tranmission
Went out this weekend and was spraying, broke something in the tranny. The car now doesn't want to shift out of second gear. Finally, gets out of 2nd gear when I slow down or speed up really fast. If you floor it it just screams through first and goes straight to 6500 in second and stays there. Only has problem in second, wandering what I broke. Someone told me that it was a sprag and if so what is that? Or what else could it be. Would appreciate any responses.
Old Nov 19, 2002 | 03:43 AM
BROKKANIC's Avatar
Suspended
Did you check the kickdown solenoid and/or the shift linkage?
If they check out then you probably damaged a planetary assembly or band.
Old Nov 19, 2002 | 09:08 AM
What transmission?
Old Nov 19, 2002 | 11:46 AM
383 N20 TA's Avatar
My fault it's a 4l60e in a 93 Trans Am.
Old Nov 20, 2002 | 11:12 AM
Are you sure its a 4L60E? How are you controlling it electronically, or have you upgraded to a 94+ PCM??????
Old Nov 20, 2002 | 07:34 PM
redemn93's Avatar
i own a 93. its definately a 700R4. im having problems too(118,000miles with LOTS of track time). my problem is with second also. i think its the converter though. if i hit it around 55-60mph it studders alot, still pulls but studders big time. its like the convertor has problems locking up or something ireally dont know. oh it also wont go into 4th at WOT, ive gone 5800 rpm in third. any ideas, besides getting a new one?
BluBiU
Jul 18, 2006 06:37 PM
Chris9450
3rd Gen / L98 Engine Tech
Oct 27, 2004 10:24 PM
brandboZ28
Sep 1, 2004 06:12 PM
Z28WannaB
May 23, 2004 07:24 PM
klumb15
18
Mar 17, 2004 03:24 PM
