is this good fluid?
Old Jun 28, 2006 | 03:55 PM
nodnarb481's Avatar
is this good fluid?
I am having my shift kit modified for free tomorrow at my neighbors garage right after i get off work. So i had to go out and get fluid. I couldnt get to pepboys because the highway was backed up for miles and miles. I couldnt get to autozone because the bridge was closed. Just short of stabbing someone i went to the nearest parts store i could find. So i got this fluid, it was the only dexron III stuff there. Its from a company called Parts Master. I was wondering if this would be a good idea to use this fluid or if i should put off this whole thing so i have time to get some kinda better fluid. Or does it just not matter as long as its the right stuff?
Old Jun 28, 2006 | 11:16 PM
nodnarb481's Avatar
Re: is this good fluid?
yeeepp so i guess ill send this one on its way back up there to the top..
Old Jun 30, 2006 | 05:53 AM
rskrause's Avatar
I am a "brand name" sort of guy for vital fluids. Though it will probably be fine, as it is almost certainly made by one of the big refiners and packaged as a "private label" brand.
Rich
Old Jun 30, 2006 | 09:29 AM
nodnarb481's Avatar
thanks.. i left it to last minute and then was completely screwed by closed down bridges and evacuated towns in my area for the flooding. I had to buy this because we were going into my transmission to change up the transgo kit a little...OH BOY was that an interesting adventure. I have to go back to my friends garage to finish today. To start the pressure was over 150. And then to continue apparently the only thing installed from the transgo kit was the serperator plate which was the shop that installed it just drilled the **** out of...
PCLZ28
Dec 24, 2015 05:19 PM
jackpawt883
Feb 26, 2015 09:04 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
