BOosted tunning.. New idea? Possible?
Old Jun 1, 2004 | 02:54 AM
Highlander's Avatar
After giving it a thought... i was thinking about using the ECT as an imput for boost to the PCM...
The PCM has a few things that could be used for boosted tunning on a car...
The main one would be the PE vs Coolant temp...
We could have a switch so when the car enters boost it will switch the signal instead of the coolant sensor to the pcm it uses the map signal to the PCM...
I think this would command the PCM a higher temp and then you can adjust for boosted operations...
I was toying with this idea and it could be feasable and be made to work...
THe downside would be that the fans will turn on and I know there are a few others... the ECT timing tables can be adjusted for offsets for different boosted levels and such...
I think its a good idea.. but im one sided now..
let me know what you guys think.
BTW the inputs for map and ect are both 0-5v.
Take care...
Dec 1, 2016 05:37 PM
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
asilomar244
Jul 12, 2015 05:53 AM
ducttape1975
Jul 10, 2015 06:29 PM
