High Idle
Re: High Idle
that sounds fine to me... mine does that too and will go to 900 and stay there perfect unless im wrong
Re: High Idle
You indicate you have an auto trans. Apparently you swapped the gears to have 3.42's. Stock idle programming fully warmed up is 650 RPM in neutral, and 550 RPM in gear. Stock tach can read 100 - 200 RPM above actual engine RPM. Put a scanner on the PCM to get the true idle speed.
The PCM is programmed to raise the idle on cold start, based on coolant temp. It can go as high as 1,200 RPM with sub-0°F temps. Idle speed will drop gradually as coolant warms up.
ChrisFrez
03-01-2015 01:33 PM
