Fusible links
Old 02-18-2016, 11:42 PM
blac94Z's Avatar
Fusible links
Need assistance identifying which one is C for the Fans Correct me if I'm incorrect thanks in advance
blac94Z is offline
Old 02-19-2016, 12:07 AM
Fatdog2's Avatar
Re: Fusible links
When you stand in front of the car facing the fuse box it's the red fuse on the right between the orange and yellow fuse.(10 amps).I think that is what you asked.hope this helps.
Fatdog2 is offline
Old 02-19-2016, 11:11 AM
Re: Fusible links
The fusible links aren't in the fuse box. They are part of the wires attached to the red plastic "+" terminal box on the passenger side inner fender, near battery. One of those supplies 12V power to the fans. The fuse in the under hood convenience box is for the fan control relays.
From Shoebox:
http://shbox.com/1/fusible.jpg
Maybe Rob knows how to tell them apart.
The 94 factory manual indicates it is 1 sq mm "rust" color (the stripe?? - but they are all labeled as rust???).
Injuneer is offline
Old 02-19-2016, 11:47 AM
blac94Z's Avatar
Re: Fusible links
Yea fat dog thanks but i need the links on the left side under hood
and mr.fred thanks i know when i did my head lights i was able to tell them apart by the number of wires come from the fusible link it self
blac94Z is offline
Old 02-19-2016, 04:03 PM
Re: Fusible links
You could narrow it down by the size that Injuneer indicated, but you'll really need to use a meter to determine which one it is.
shoebox is offline
Old 02-19-2016, 04:25 PM
blac94Z's Avatar
Re: Fusible links
Ok i will have to check it after work today im just going to buy a meter also from harbor frieght
blac94Z is offline
Old 02-19-2016, 09:32 PM
Fatdog2's Avatar
Re: Fusible links
My bad.Anyway,I got a free meter from Harbor Freight on one of their ads when you make a purchase of any amount.Check it out.They have the ads laying around there.I just don't know how to use it so it collects dust.My brother-in-law knows how to use these,I just need some schoolin and patience on it. Hope this helps.
Fatdog2 is offline
Old 02-19-2016, 11:13 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Re: Fusible links
Locate the link wire pair that shares the same terminal and has two "1.0 SQ mm" links. That pair should have one link for the hvac blower and another for the fans. Confirm that by disconnecting all but that pair from the post and seeing if the blower operates. I can't tell you how to determine which of the two is for the fans.
GaryDoug is offline
Old 02-21-2016, 01:52 PM
blac94Z's Avatar
Re: Fusible links
thank you guys I located the wire pair and those where the two i changed and it worked one wire was burned in the middle internally.
blac94Z is offline
Old 02-21-2016, 04:54 PM
Prominent Member
GaryDoug's Avatar
Re: Fusible links
Way to go. Wish they would make them easier to trace.
Fatdog2:
That meter you got will probably have at least one bad probe lead. Every one i have gotten has been able to be easily pulled apart from the probe tip. The only way I know to fix that is 1) buy a pair from somewhere else or 2) cut apart the probe so that you can solder the wire back to the tip, then epoxy the probe back together.
GaryDoug is offline
Old 02-21-2016, 10:45 PM
Fatdog2's Avatar
Re: Fusible links
Fatdog2:
Nuts.OK Thanks.
Fatdog2 is offline
Hawkman978
02-03-2016 04:05 PM
Hawkman978
01-20-2016 12:48 PM
The Guz
12-23-2015 01:09 AM
sideways_Into_3rd
02-14-2003 10:38 PM
jfischer
08-30-2002 07:58 PM
Quick Reply: Fusible links
