the chevy 5.7 ls1 is the same as the pontiac 5.7 ls1 right?
#16
Originally posted by NoSlowCamaro
yea man..everything is like identical..supposedly a buddy of my'n claims to have seen a WS6/SS hybrid..he said that it was dark blue, and from the back it looked like an SS..it had the spoiler, and the SS badges on the back...he said the front of it looked just like a WS6..he said when he was coming up on it, he was saying "cool SS", he said when he passed it he wasnt sure what he was seeing..so he slowed back down and sure enough..it was an SS rear with the WS6 front..he said the liscense plate read "hybridSS"
#17
Originally posted by Indelibility
Neither is he if he's asking if the LS1 is different in the Camaro and Trans Am
obviously your a dumbass, where do you see in my post where im ASKING if hes correct or anything like that, buzz off troll
#18
Originally posted by Capn Pete
^ ^ ....it probably had the WS6 look-a-like hood on the SS? You know, the one with the same ram-air "nostrils" as the WS6 has?
#19
The test model from GM with half TA and half Camaro panels did not have a uniform look. Where the TA met the Camaro just didn't line up. So, unless his car looked retarded as hell from the side, it didn't have a swapped doghouse.
Most likely explanation is the guy didn't know what he saw.
WS6's and Firehawks run slightly faster than SS's because of where the IAC (inlet air something) is located more foward under the hood, where the air is cooler - instead of closer to the engine. There's a mod with a resistor to trick it into thinking the incoming air temp was always lower than it would ever be in the summer (30-60'?).
But the IAC position difference of SS/WS6's isn't something that would determine a winner in a street race IMO.
#22
Originally posted by redzsmoked212
if im not mistaken i thought it was the vettes that had the electronic controlled trottlebody.
Originally posted by NBS4
Only difference between the LS1 in the C5 and the F-body is that the Corvette has Throttle by Wire
305fan
09-08-2002 08:13 PM
Hoodshaker
08-27-2002 02:32 PM
whuzizname
12
07-22-2002 07:52 PM
formula79
18
07-01-2002 02:39 PM
