can I remove ac from my camaro?
I have a 1995 camaro z28 I am rebuild the motor ac is no good and I want to do away with the ac compresser just dont know please help?
P.S I am going to put a cam in the lt1 how big can I go with out change chip,computer it is a 6 speed car?
Bill
Bill
Installing a more aggressive cam without a custom flash tune (no chip in your 95) is a waste of money. You can pick up 10-15HP with a tune on a stock cam/stock engine. Install a cam without tuning it, and you leave HP on the table and will probably have drivability issues.
99firehawk#312
Why did you "report this post"? Did you mean to hit "reply", and hit "report" by mistake?
If you meant to ask about the AC delete pulley, yes, this is the pulley that was used in place of the AC compressor, on the 1LE models that did not have AC. You can get them from several sources, but a GM part is going to be more reliable. Shoebox has the part # on his website:
http://shbox.com/1/Parts.htm
99firehawk#312 ( mailto:billandmarie.1@netzero.com ) has reported this post:
https://www.camaroz28.com/forums/sho...74#post6191774
This is part of this thread:
https://www.camaroz28.com/forums/sho...d.php?t=725030
This is the reason that the user gave:
is it a pulley that go in it place ? do you have a web site? thanks
This message has been sent to all moderators of this forum, or all administrators if there are no moderators.
Please respond to this post as applicable.
Mikes 1994 z28
11-25-2014 02:00 PM
07-04-2005 05:00 PM
