94 Z Limp Mode ?
Old 11-16-2013, 12:37 PM
Danok72's Avatar
94 Z Limp Mode ?
Yep after doing some research on the forum it sounds like my car is in limp mode, Only has one forward gear and no overdrive. I have replaced the 2-3 solenoid and no change. My car had a 3.23 rear and swapped in a 3.42 in its place recently. Would this have fried my P.C.M. and caused this ? Is this a P.C.M. issue or a trans issue ? I am dead in the driveway until I can figure this out !
Danok72 is offline
Old 11-16-2013, 04:12 PM
Re: 94 Z Limp Mode ?
Did you scan the PCM for transmission codes? They don't turn on the SES light.
Changing the rear axle will not "fry" the PCM.
Injuneer is offline
Old 11-16-2013, 06:34 PM
blown94's Avatar
Check trans fuse
blown94 is offline
Old 11-17-2013, 09:02 AM
12SCNDZ's Avatar
As Injuneer said, check it for codes. Is it 1st gear or 3rd gear it's trying to take off in?
Frank
12SCNDZ is offline
Old 11-17-2013, 10:21 AM
Danok72's Avatar
Takes off in third, no lights come up on the dash. I will check the trans fuse.
Danok72 is offline
Old 11-17-2013, 11:54 AM
Already explained- trans codes do not turn on SES light.
Injuneer is offline
Old 11-17-2013, 06:29 PM
Danok72's Avatar
What is the "SES" light ?
Danok72 is offline
Old 11-17-2013, 06:34 PM
Service engine soon. It's a light on the dash that comes on when the PCM (powertrain control module = computer) sets a diagnostic trouble code.
You need to read your Owner's Manual.
Injuneer is offline
Old 11-27-2013, 01:10 PM
Danok72's Avatar
After doing more research and reading up on what other people have done and aside from Injuneers helpful "read your owners manual" comment I replaced the PCM and all is well. Thanks to those who were helpful on this.
Danok72 is offline
Old 11-27-2013, 01:47 PM
Thanks for the PM calling me a "jerk" for trying to help you. I'll know better next time. Grow up.
Injuneer is offline
drt
09-27-2015 04:39 PM
autoxr166
09-25-2015 04:21 PM
MDZ28
11
09-24-2015 09:15 AM
4586
08-24-2015 11:04 PM
08-07-2015 08:52 AM
Quick Reply: 94 Z Limp Mode ?
