94 Z Limp Mode ?
Yep after doing some research on the forum it sounds like my car is in limp mode, Only has one forward gear and no overdrive. I have replaced the 2-3 solenoid and no change. My car had a 3.23 rear and swapped in a 3.42 in its place recently. Would this have fried my P.C.M. and caused this ? Is this a P.C.M. issue or a trans issue ? I am dead in the driveway until I can figure this out !
Re: 94 Z Limp Mode ?
Did you scan the PCM for transmission codes? They don't turn on the SES light.
Changing the rear axle will not "fry" the PCM. |
Check trans fuse
As Injuneer said, check it for codes. Is it 1st gear or 3rd gear it's trying to take off in?
Frank |
Takes off in third, no lights come up on the dash. I will check the trans fuse.
Originally Posted by Danok72
(Post 6953890)
What is the "SES" light ?
Service engine soon. It's a light on the dash that comes on when the PCM (powertrain control module = computer) sets a diagnostic trouble code.
You need to read your Owner's Manual. |
After doing more research and reading up on what other people have done and aside from Injuneers helpful "read your owners manual" comment I replaced the PCM and all is well. Thanks to those who were helpful on this.
:confused:
Thanks for the PM calling me a "jerk" for trying to help you. I'll know better next time. Grow up. |
