Anyone with Jet Hot LT's come in please, have a question
Old Mar 21, 2003 | 06:33 PM
96Z28man's Avatar
That's kinda weird how the one header comes with one tube disassembles and has to be slipped on seperate. Should I put this piece on before or after installation to make it easier? Will just sliding it on keep it from leaking?
Old Mar 21, 2003 | 06:39 PM
KY95Z28's Avatar
I have had both Hooker's and Jet-Hot Lt's. I just installed the Jet-Hot's this past weekend, put the slip tube on after you have bolted the header down. Your steering arm/linkage with have to be unbolted. My Hooker slip tube fit very loosely and leaked, the Jet-hot slip tube was a very tight fit and required wd-40 to get it to slide all the way in and I have had no leaks as of yet.
Good luck.
Nick
Old Mar 21, 2003 | 07:27 PM
bad95z28's Avatar
my hooker slip tube fit so damn tight that i almost never got it on. it doesn't leak at all.
Old Mar 23, 2003 | 10:20 PM
thebrainhart's Avatar
Yeah, after the rest is loosley bolted on. Mine was hard, but get a rubber mallet, and tap it while somebody else tries to twist it from underneath. I didn't disconnect any steering linkage. But it was a tight fit.
LT14LIFE
Feb 9, 2015 09:35 PM
bandit383lt4
Dec 21, 2014 09:12 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
RedLineRev
Jan 23, 2003 03:51 PM
ferraricameron
Jul 29, 2002 07:46 PM
