Found an Exploded View of the T56
Old Mar 11, 2003 | 09:23 AM
Gripenfelter's Avatar
http://www.highperformancepontiac.co...LLET07zoom.jpg
"Here is an exploded view of the trans case showing the 6th gear and reverse assemblies. Note that the T-56 has designed into it a constant mesh, synchronized reverse system, which provides more positive engagement, reduced noise and improved durability".
http://www.highperformancepontiac.co...LLET08zoom.jpg
"This view illustrates how the 1st and 2nd gear assemblies fit into the case".
http://www.highperformancepontiac.co...LLET09zoom.jpg
"Exploded view of adapter plate and gears: Here we see how the main shaft and the input shaft and gear assemblies attach to the front adapter plate".
http://www.highperformancepontiac.co...LLET10zoom.jpg
"Exploded view of shift shafts and clutch cover: The T-56 uses an internal single rail shift system to improve shift feel and durability over the old external shifter and rod designs that are exposed to the elements and require periodic lubrication and maintenance".
http://www.highperformancepontiac.co...LLET11zoom.jpg
"Exploded view of extension housing: These are the parts that go into the extension housing".
http://www.highperformancepontiac.co...LLET12zoom.jpg
"Exploded view of reverse lockout and shifter".
Old Mar 11, 2003 | 09:35 AM
So, the views in the T56 repair manual are not good enough for ya?
Old Mar 11, 2003 | 10:16 AM
Thanx for the link shoe.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
cmsmith
Apr 11, 2015 09:37 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
HuJass
18
Jun 24, 2002 09:19 PM
