Fpss ?
Old Feb 24, 2003 | 08:48 PM
dkeers's Avatar
Fpss ?
I just got my fpss in the mail from Jeg's, but it is the one for 4-7 psi. I want to run it after my fuel solenoid and only grounding the nitrous solenoid. This way if the fuel solenoid sticks the nitrous solenoid won't open. Will the switch I got be fine for this. I am not worried about the switch making sure the fuel pressure is low. It should turn on when it sees any pressure even if it is 50 psi right? I really don't want to have to pay and send it back.
Thank you
Dustin
Old Feb 25, 2003 | 11:19 AM
95greendragon's Avatar
Unless you are carb'd you will need to send it back. That is the FPSS for carb'd applications. They tried to sell me that one when I ordered mine. I've got mine set a 35psi, if it drops below that it cuts the relay to the solenoids. The carb'd one is going to cut it at 5-7 psi, you will be in big trouble way before it drops that low.
Old Feb 25, 2003 | 05:15 PM
dkeers's Avatar
I'm sending it back. Thanks.
Old Feb 27, 2003 | 10:07 AM
therealmagyver's Avatar
Mine came from NOS with no intructions on how to adjust. If I unscrew it does it drop pressure? I did that and now it won't work. I lost the dam screw on the inside, so I can't tighten it back.
Kris96WS6
N2O Tech
May 8, 2004 11:14 PM
craigffb
N2O Tech
Aug 24, 2003 12:21 PM
snksknr94
N2O Tech
10
Jun 16, 2003 06:45 PM
snksknr94
N2O Tech
May 6, 2003 02:34 PM
Hawk
N2O Tech
Mar 30, 2003 10:48 AM
