67 wiring schematic problem
Old Jan 21, 2003 | 09:57 PM
67Man's Avatar
Ok heres the problem, i went from a 327, to 468. My battery is connected, there is no power to anything period. I tried to turn the lights on nothing. turn signals, anything inside out side the car does not work. how ever i touched the started bolt with a screw driver and it started turning.
I chased these 3 wires around, i tried touch the battery with a light tester, it works . Then i tried testing other wires every where. Nothing. I cant figure out where the problem is, and i do not know where the hot wire is. Where can i find a diagram on 67 camaro wire schematics?
Old Jan 22, 2003 | 01:07 PM
68SuperRam's Avatar
It sounds like the fuse panel is getting 12v+. I would trace the wire from the starter (as the battery gets connected directly to the starter, and then there should be a wire from the starter to the fuse panel) to the fuse panel, and test the fuse panel to see if there is any 12v+ there. In regards to a diagram, you may to contact painless wiring, as they probably have original diagrams.
Hope this helps.
Magenta_Hearts
Mar 25, 2015 10:24 AM
Scottyboy
Feb 11, 2015 10:28 PM
GigaMp3z
Feb 20, 2003 02:57 PM
BOOGER
Jul 25, 2002 02:42 PM
