Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Ignition/starting problem
Old Nov 1, 2008 | 07:26 PM
Unorthodox_Racing's Avatar
I was pulling out of the store and my car dies. I jiggled the Ignition key and finally found the sweet spot where it seemed to have engaged and my "start-up" lights on my dash came on. I drove maybe 20 ft and the same thing happens. I did the same thing again and it worked so I go onto the interstate and made it about 14 miles when my car dies again. But, before it dies my speedo and tach go haywire. I pull of to the shoulder and when I turn the key nothing happens... ie, my fuel pump doesn't prime, my start-up lights on my dash doesn't come on and most importantly... my car is completely silent when I try to start it. Nothing clicks, nothing pops, and nothing happens.
I replaced the Ignition Cylinder today and that didn't remedy it. My next guess is ICM, relay or some little midget that I pissed off a few years ago inside my steering column saying "**** you!"
Note: My starter is also engaged by a push button
Old Nov 1, 2008 | 09:29 PM
Could it be my Ignition Switch?...
Old Nov 1, 2008 | 11:27 PM
Check out Shoebox's ignition switch repair procedure. Appears to describe your symptoms:
http://shbox.com/ignsw/ign_switch_repl.html
Old Nov 2, 2008 | 01:23 AM
You are too awesome! I've never had anyone give me help when I was a rustang guy. Gotta love the GM brotherhood
Old Nov 2, 2008 | 10:16 AM
Last week I sinned... guy across the street from my house asked me to look at his 92 5.0 with a new Kenne Bell S/C. He was having major belt alignment problems. Guy who replaced his power steering pump had tried to fix the belt problems by not putting the PS pump pulley on all the way... what a mess. I have no pride.
Old Nov 2, 2008 | 12:14 PM
well Im about to tear into dash and try out what you sent me last night. keep fingers crossed. I hate seeing it sit in my garage.
Old Nov 2, 2008 | 07:18 PM
Well boss... IT WORKED! I was able to do it without completely removing the column. it was cramped but the hardest part was reinstalling the black cable into its slot. My blue connector as well as the corresponding portion of the switch was burnt.
Once again sir... thank you!
Old Nov 2, 2008 | 08:03 PM
Green96Z's Avatar
I guess I'm in the same boat is you Fred. I changed the oil on my brother's 88 5.0 for him. I swear that thing was held together by duct tape.
Old Nov 27, 2008 | 01:34 PM
jcurrieirocz's Avatar
my car is acting the exact same way??? but now it wont go if i wiggle it or not.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
