trans slip from stop
Old Sep 5, 2008 | 07:44 PM
arctic white 94's Avatar
My car just started doing this the other day. It is a 94 z28 with the 4l60-e. If I put the shifter in drive or overdrive it will rev up to about 1100 rpm in first before it will move. If the shifter is in 2nd it takes off normal. It is not throttle dependent. The check engine light is not on. Sometimes it will shift kinda slow. The car is missing kinda bad. Would the miss cause this or is it something more serious. Thanks for any help.
Old Sep 5, 2008 | 08:15 PM
12SCNDZ's Avatar
It sounds like you're seeing early signs of forward clutch failure. What condition is the fluid in? Is it discolored, or does it have a burnt smell?
Frank
CPT
Old Sep 5, 2008 | 08:45 PM
The fluid looks fine. I havent drove it since it started acting up. I was hoping that it would be because of the miss but o well.
Old Sep 5, 2008 | 09:04 PM
Would it cause more damage if I keep driving it or would it matter since the forward will have to be replaced anyways?
Keenan
Jan 19, 2023 12:24 PM
blkWidow
Apr 21, 2015 01:56 PM
jackpawt883
Feb 26, 2015 09:04 PM
MattFick
Feb 15, 2015 10:16 PM
IgorT.455/406
Jun 4, 2003 03:32 AM
