Gear swap major issues need help
First off let me say im new here and need some help after my recent gear swap. I have a 1995 Z28 with headers, CAI, TB plenum, Cat delete, 160tsat and a 1 year old rebuilt auto tranny. I recently changed my ratio from a 2:73 to a 3:43 rear gear and am having severe issues. First off the gear is from Richmond and whines at real low speeds and right when put under initial load, secondly when i give the car hard throttle (its an auto) its like holding the clutch in on a manual and it hits the rev limiter and wont shift, when you let off the gas it finally shifts. When i first bought the car it had the same problem, but i rebuilt the tranny. Im at my wits end here and really upset so any help would be nice
thanks..
thanks..
The trans will not function correctly without the proper VSS signal and if you haven't reprograms for the gears it is not seeing what is expected and will not function properly.
I know alotta LT-1 guys use PCMS FOR LESS.
To address the other issue you mentioned... if the gears are whining, you may need to adjust the backlash. This is done by adding/removing shims. I'm sure someone here can give you more detailed instructions if you need it.
Also, it's 2.73:1 and 3.42:1, not 2:73 and 3:43. You can leave off the ":1" if you want.
Your 95 has a 16-pin ALDL port, but its not an OBD-II PCM. Still OBD-I.
The Hypertech Power Programmer adjusts for the rear axle ratio. In the instruction book its option F., and as you step through the options its right after the Tire Size, and right before the Shift Point screens.
It calibrates the speedo by allowing you to enter the correct rear axle ratio and the correct tire diameter.
and will need to replace or rebuild. Give me a call if you like
