Turbo Build
Old Dec 20, 2007 | 10:31 PM
c0rey's Avatar
Turbo Build
First and foremost I wanna thank RealQuick (www.lt1boost.net) for giving me advice on this. Thanks alot man wouldnt have known where to start without ya!
Here are the car specs.
96 z28
Stock Rebuilt Engine (not cool)
224/236 Cam
3600 Stall
Walbro 255
42.5 Lucas Inj.
Stock Radiator in Stock Loc.
Flex a-lite slim fans
Master Power T-70 .96AR
2.5 Pass Log
2.5 Crossover
3 in. Main Log
3 in down pipe hooked up to Magnaflow catback.
xo2 racing 44MM Wastegate
xo2 racing 50MM BOV
FMIC
Well got the logs mostly done. Still need to clean up the welds with a grinder. The welds didnt turn out as clean as I wanted but its my first time doing a turbo kit with a cheap welder :thumbup Great learning experience so far.
Old Dec 21, 2007 | 10:02 AM
Tricked-Out-Toy's Avatar
SWEET! looks liek a nice little setup. the pass side header looks great!
Old Dec 21, 2007 | 10:19 AM
c0rey's Avatar
Drivers side will look alot better with some grinder work.
Old Dec 21, 2007 | 11:57 AM
RealQuick's Avatar
Great job dude! Its getting there. Double check you will clear the k-member where the pass. side log drops down and also the clearance for the starter. You might be fine, but just double check.
Jon
Old Dec 21, 2007 | 12:09 PM
c0rey's Avatar
Well got the flanges on tuesday and been working on it after work some. Coming together very quick. I know it clears the k-member but forgot to check the starter
Old Dec 21, 2007 | 12:25 PM
Eric Bazan's Avatar
Lookin' good
Old Dec 21, 2007 | 03:09 PM
c0rey's Avatar
Wastegate placement? Crossover, or can I do it at the main log before the turbo? Vent to atmosphere or run into the downpipe?
Old Dec 21, 2007 | 03:29 PM
Eric Bazan's Avatar
I would place as close to your turbo as possible. Here is where I placed mine. I vented to atmosphere. I think its a matter of personal prefrence.
http://www.fquick.com/garages/viewga...ewimg&id=53477
Old Dec 24, 2007 | 05:41 PM
c0rey's Avatar
Its almost done. The headers/crossover/and downpipe are all done so far.
List of stuff left to do.
Oil line(3/16 hard line)
Oil return (5/8 heater hose to front of pan??)
02 sensor poistioning
Wastegate(gonna have to go on the crossover)
Load new tune
Then all the cold side piping. Working on the intercooler mounting and coldside tonight probally. Gotta get it done to have the machine shop tig the bov on.
Will finish up the thread with pictures of everything when its done. Then get a video.
Everything seems to be coming together very quick
Old Dec 24, 2007 | 06:41 PM
RealQuick's Avatar
come on, dont tease us! Lets see some pics
Old Dec 24, 2007 | 09:34 PM
c0rey's Avatar
Here is what I have done tonite.
Mounted intercooler
All Hot parts Done
02 installed
Wastegate Installed
Down pipe Connected to exhaust.
Dont mind the air fiter it was one I had laying around the shop.
For the oil feed and return the turbo has a -4an fitting for feed, -10 an for return. Where is the best place to buy the turbo feed? What size of adapter do I need to come outta the block? For return do they make a weld-able an fitting?
Also got a digi camcorder for x-mas
Old Dec 26, 2007 | 10:21 AM
RealQuick's Avatar
Looks great!
Old Dec 26, 2007 | 11:36 AM
c0rey's Avatar
Someone keeps telling me its gonna be to low from gravity return...
Old Dec 26, 2007 | 11:53 AM
jsetzer's Avatar
I can't tell quite how high it is, but you may be ok. As long as the outlet on the turbo is higher than the point in your pan, and it slopes down to the the pan you are ok.
Old Dec 26, 2007 | 12:00 PM
c0rey's Avatar
Bottom of the turbo is pry 2-3 inches from the sway bar it looks quite a bit higher than the front of the pan.
